A cement mill is the equipment that used to grind
Home / Forums / Main Forum / Introductions / A cement mill is the equipment that used to grind
- This topic has 0 replies, 1 voice, and was last updated 12 years, 4 months ago by dream.
A cement mill is the equipment that used to grind the hard, nodular clinker from the cement kiln into the fine grey powder that is cement. Most cement is currently ground in ball mills.The cement manufacturing process consists of many simultaneous and continuous operations using some of the largest moving machinery in manufacturing. Cement clinker is usually ground using a cement ball mill. This is essentially a large rotating drum containing grinding media – normally steel balls. As the drum rotates, the motion of the balls crushes the clinker. The drum rotates approximately once every couple of seconds.Grinding systems are either ‘open circuit’ or ‘closed circuit’. In an open circuit system, the feed rate of incoming clinker is adjusted to achieve the desired fineness of the product. In a closed circuit system, coarse particles are separated from the finer product and returned for further grinding.
This cement ball mill is mainly used in grinding cement finished products and raw materials and also suited to metallurgical, chemical, electricity etc. and other industrial mining enterprises. It could also be used to grind various ore materials and materials that is grindability.Cement mill is the equipment used to grind the hard, nodular clinker from the cement kiln into the fine grey powder that is cement. Most cement is currently ground in ball mills.Cement mill is normally driven by electric motors.The output achieved by a cement mill system varies with the mill power, the fineness of the
product and the hardness of the clinker.In the technics of Cement production process, People usually choose limestones and clays as the main raw materials, crushing, concocting, grinding them into cement raw meal, feeding them into cement kiln,Cement clinker is usually ground using a ball mill.After being calcined maturity, adding appropriate amount of gypsum (sometimes mixing the mixed material or admixture) then being grinded, and the cements form.
1 Crushing and pre-homogenization
2 The prepare and homogenization of cement raw meals
3 Pre-decomposition and the burning of cement clinker
4 Cement grinding
Hongxing Machine not only have skilled technicians and experienced service team, we also apply Internet technology into all aspects of production and management process which can provide timely provision of the latest products’ information and technical services. We provide the best warranty and extended warranty plan for our products.
FeaturesTechnical data
1. Strong adaptability;
2. Continuous produce;
3. Broken rate large;
4. Easy to adjust the product grinding fineness etc;
5. It can not only produce with wet type, but also grind and dry simultaneous
E-mail: sales@hxjq.com
cement grinding machine: http://www.sell-crusher.com/pro/p32.html
