autoclear III ?????
- This topic has 1 reply, 2 voices, and was last updated 11 years, 8 months ago by .
Home / Forums / Main Forum / Paint and Refinish / autoclear III ?????
any 1 spray autoclear III ???/what is the best way to mix it hardner suggestions ???/spraying in cross flow booth ,75 deg
Sprayed it for many years.You have a couple of choices for hardeners,standard or xp hardener with a wide range of activators(production,medium,standard,extra slow also).Mix it the way the tds states for the specific hardener you are using as both ratios are different.Pretty easy clear to spray and it will like a larger tip like a 1.4 in an rp.
