Automatic needle machine item introduction, struct
Home / Forums / Main Forum / Introductions / Automatic needle machine item introduction, struct
- This topic has 0 replies, 1 voice, and was last updated 11 years, 8 months ago by fdbfdb.
Full automatic needle machine is applied to verify the soft cotton broken needle along with other pieces of metal, when detecting the broken needle and iron compounds, acousto optical instrument and alarm, the conveyor belt to return or stop.
Product functions:
Higher sensitivity photoelectric switch http://www.zjhollphy.com/three-system-computerized-flat-knitting-machine-with-comb-123.html
computerized flat knitting machine control magnetic field work;Sensitivity indicator;
Detection sensitivity indicator;
LCD detected object quantity show;
LED detecting position indicator;
Automatic, manual switch;
Thick, thin sample mode switching;
Bad item sound, light double alarm;
Negative item rewind, cease band switching;
Ad hoc with no detection of idle ten minutes automatic shutdown function;
Advantages: the automatic needle machine costs had been somewhat low cost, suitable for the majority of sewn items only must detect the broken needle detection items (such as: must be installed copper or non ferrous alloy button, zipper, clothing, toys, beads, handbags as well as other sewn merchandise). Has been accepted by the masses of customers. http://www.zjhollphy.com/computerized-single-system-flat-knitting-machine-22.html
computerized single system knitting machineAt present Chinese home provided that the needle machine functionality of typical manufacturer production delivers the basic can and imported machine match.Upkeep of widespread sense:
For the reason that the machine is often a high sensitive detection gear, towards the environment and machine maintenance is reasonably extra stringent requirements. So just after a period of use, to make sure the regular use, you’ll want to do on a daily basis standard cleaning of conveyor belt and also other conveniently soiled components.
1, clean appliance: find a clean towel, wet water twist dry until can’t hold water.
two, the Sweater Knitting Machine: interest, prior to cleaning need to be the very first needle detector sensitivity adjustment to the lowest level, like needle machine with B/C mode to C mode, please put the needle machine adjustment, cleaning to avoid higher sensitivity affects the subsequent. Then the towel straightened and adequately pressed on the surface on the conveyer belt, get started the machine, the machine operates more than 5 cycles (in an effort to pollutants, clean the surface of the conveyer belt approach is often flexibly applied), then clean towels wrung, repeat this step till the wiping conveyer belt, conveyor belt surface no apparent contamination so far;
three, the conveyor belt cleaning: back then rinse wrung from the decrease part of the machine, the towel via the conveyor belt in the bottom, straighten the towel,
The towel is pumped towards the conveying table front, seize the towel at each ends, start out the machine to produce the machine functioning weeks. The conveyor belt at the bottom could be the most dirty place, the have to have for repeated wiping. Every single operation after some weeks, will wash towels out once again to repeat the above measures.
4, tips on how to judge the cleaning impact: Needle detector machine conveyor belt via the two cleaning step, the sensitivity is adjusted to eight grade or the highest sensitivity, start out the machine, let the machine run, like a machine running smoothly and the probe metal position display light will not shine, this time in to the non metal impurities clothing, clothing is
http://www.zjhollphy.com/sweater-knitting-machine-110.html
Sweater Knitting Machine often smoothly the needle detector channel, namely the conveyor belt cleaning results.- AuthorPosts
