Black 87 Buick Regal is finally done
Back to: Gallery2 Replies
Home / Forums / Main Forum / Gallery / Black 87 Buick Regal is finally done
- This topic has 2 replies, 2 voices, and was last updated 12 years, 6 months ago by Josh.
I finished up this T-type Buick Regal a couple weeks ago. The car is pretty strong, the turbocharged 3.8 pushes it to 12.70’s at the local drag strip. Anyway, I went all the way to metal, epoxy, body work, 2 coats of high build, block sanding, 2 more coats of high build, another coat of DP90 so it would be black under the black paint, 3-4 coats of Deltron black, and 3 coats of DC2021 clear. Opinions, suggestions, and criticisms are welcome, thanks!
