brother dans first plastic repair
Home / Forums / Main Forum / Auto Body Repair / brother dans first plastic repair
- This topic has 12 replies, 8 voices, and was last updated 16 years, 7 months ago by Dennis B..
- July 30, 2009 at 12:49 am #15038
hey he even watched the dvd that came with the welder :blink:
[IMG]http://i151.photobucket.com/albums/s151/jackcarlson1965/DSCN3505.jpg[/IMG]
[IMG]http://i151.photobucket.com/albums/s151/jackcarlson1965/DSCN3506.jpg[/IMG]
an one of the core support he gets ta replace tomorrow
[IMG]http://i151.photobucket.com/albums/s151/jackcarlson1965/DSCN3504.jpg[/IMG]July 30, 2009 at 1:05 am #15040was going ta see about trying ta save it but for 33$ it just aint worth it
July 30, 2009 at 4:23 am #15044good after he switch rod ended up using the fiberflex on it to luv it though he had all sorts of ideas after the dvd he watched yesterday :stoned
July 30, 2009 at 3:34 pm #15050Most times I don’t use the fiberflex. I have gone to using strips of old bumper. Use the flat foot with the welder on high and it works pretty well.
AnonymousJuly 30, 2009 at 3:46 pm #15052Looks good bondo. That’s something I want to learn about too (plastic welding). I should pick one up myself, just looks like a soldering iron with a funky end. How doe’s the strength of a plastic weld compare to epoxy repairs? Also, are you sucking up a lot of harsh fumes doing this?
Jimmo, the welder is a breeze to use. And those tiny rods last forever. The fiberflex isn’t as strong
as a 2 part adhesive; i prefer using 3M Structural adhesive or even JB Weld for headlamp tabs (PP).
Headlamps, air cleaner boxes, or even just one bumper and the welder kit pays for itself. It’s a must have.July 30, 2009 at 8:33 pm #15059Well i just discovered my helper welds metal like your helper welds plastic :S trying to weld sheetmetal with a 110 welder on the lowest heat setting :wak
July 31, 2009 at 3:06 am #15064this is what happins when ya use the wrong rod on the wrong plastic at least it came off easy :exci :exci
[IMG]http://i151.photobucket.com/albums/s151/jackcarlson1965/DSCN3508.jpg[/IMG] - AuthorPosts
