Can I use Centari 793s Hardener in Nason paint?
Home / Forums / Main Forum / Paint and Refinish / Can I use Centari 793s Hardener in Nason paint?
- This topic has 2 replies, 3 voices, and was last updated 12 years, 8 months ago by Ben Hart.
- June 28, 2013 at 2:50 am #43452
Hi all,
I was wondering if Dupont Centari 793s Gloss hardener can be used (substituted) in Dupont Nason Ful-Cryl Cat II Acrylic enamel paint?
Reason being is that I have A LOT of Centari 793s lying around the shop.
Since they are both Acrylic enamel paints I was wondering if the Centari 793s hardener could be used as a substitute hardener?
cheers….
AnonymousJune 28, 2013 at 3:43 am #43454I just have to say first off, stick to the tech sheet and use the right stuff…and old hardener may not be effective as it does have a somewhat short shelf life.
But, people had a lot of success using the off brand universal acrylic enamel hardener. Therefore using the 793 in the Nason should be just fine. It is probably the same or better than the Nason stuff. If I recall, I think the mixing ratio for Centari and Nason acrylic enamel are similar or the same. You could always phone your local DuPont tech rep and confirm this.
Good Luck
