ford guardsman blue
Home / Forums / Main Forum / Paint and Refinish / ford guardsman blue
- This topic has 3 replies, 2 voices, and was last updated 10 years, 11 months ago by Jayson Munro.
- April 13, 2015 at 2:21 pm #48627
Trying to see if anyone here has a paint code for Ford Guardsman blue. I think that it came on some of the old mustangs. I will be spraying this in Sikkens ABP. Thanks for the help.
April 14, 2015 at 5:25 am #48628Try code “F” it comes up as a different name but it is a dark blue for 1965 mustang.
April 15, 2015 at 3:56 am #48630I found that code in the computer, but it will not pull up a mix for it. I am guessing that it might be to old of a color. I think I might look at viper blue instead. Its going on a 78 elcamino. I don’t want this color to be an issue with matching it later on down the road if need be.
Thanks for the help
April 15, 2015 at 9:58 am #48633If you wish to use the ford color use the colormap location.If you go into the computer in the standard collections then put the color map location in the akzo code section you will get an up to date formula the the CM location.This is a better option that just typing in the color map location and having the computer give up 10 choices that are somewhat close.Viper blue is also pretty sweet.
