help
Home / Forums / Main Forum / Auto Body Repair / help
- This topic has 4 replies, 5 voices, and was last updated 14 years, 6 months ago by Ben Hart.
- September 18, 2011 at 2:06 pm #32984
π Hi Guys I have a problem and I hope you can help, I am just an armature car guy trying to fix up my old ford t. I have filled and sanded and primed with a high build primer and rubbed it down. I have then put on three coats of black base coat and rubbed it down with 400 and 600 grit wet. The problem is I have a million tiny holes in the base coat do I rubbing down and painting base or what seams to me the best way is go back and put on much more filler primer. Hope this is not to boring for all you proβs out there, my thanks in advances. Richard
From what i can get out of what you are trying to say is that your holes are coming from your filler work. Im guessing that you didnt use a polyester putty over your filler. Dont apply any more filler primer, you need to sand off the primer with 180 than apply a poyester putty to fill the holes, sand than apply a filler primer, sand, sealer, base coat than clear.
September 18, 2011 at 5:39 pm #32987sand a spot down and fing out where the pinholes are coming from. then we can fix the problem π
