Introduction to the Working Process of Sludge Drye
Home / Forums / Main Forum / Auto Body Repair / Introduction to the Working Process of Sludge Drye
- This topic has 0 replies, 1 voice, and was last updated 12 years ago by oremachine.
- April 10, 2014 at 1:16 pm #46355
Sludge [url=http://www.fut-china.com/products_2_1.html]dryer machine[/url] is mainly composed of induced draft fan, scatter device, belt type feeding machine, feeding machine, rotary drum, heat source, belt type discharging machine, discharge device and distribution cabinet composition. Research and development of sludge [url=http://www.fut-china.com/products_2_1.html]drying equipment[/url] of our factory will be sludge drying, facilitate sludge biological organic fertilizer production, is organic fertilizer manufacturing enterprise of choice for drying equipment.
The sludge dryers has resistance to overload ability, large in capacity, fuel consumption, dry low cost; New type of feed and discharge device eliminate the feeding jams, discontinuous, uneven return product phenomenon, Reducing the dust removal system load, so it is a kind of high quality,environmental protection and high efficiency drying equipment. At the same time, the cleaning device buried in the material lift up along the circular arc of the plate in side down, cleaning down. adhesion material. When cleaning device with barrel turned vertically later, and in the circular raising material plate back draging, its adhesion material is cleaned down. Along with the barrel continuous rotation, so that some of the moisture evaporation, sludge further drying. At the same time, the cleaning device play a broken effect for sludge group ball. Finally after drying sludge into low moisture of loose material, it is discharged from discharge port.
Sludge drying equipment can dry all kinds of active organic sludge, Sludge is from the chute into guide plate of dryer by feeder. With the rotation of the cylinder, sludge is guide to raising material board and the material is to ascend to the center position of the cylinder, Gradually spatter forming material curtain, High temperature air through from it, make the sludge preheating and evaporation of water. When the sludge spatter, moves to the activities of the cage bar type wing, material and preheating the cage bar type wing inclusion in together, send heat to material, make the moisture evaporated. At the same time, the wing with a powder materials, spatter, repeated many times, the material and heat flow heat convection and contact.
steel slag ball press machine: http://www.ft-mac.com/pro/Steel_slag_ball_press_machine.html
