KTAG K-TAG ECU Programming Tool Vedio
Home / Forums / Main Forum / Gallery / KTAG K-TAG ECU Programming Tool Vedio
- This topic has 0 replies, 1 voice, and was last updated 12 years, 10 months ago by yi liu.
software: 1.89
hardware: 5.001
update by emailThe new K-TAG is 100% J-Tag compatible, but in a completely different way. Usually J-Tag programmers are available only for big productions, never present in chiptuning devices. Using only the essential components, Alientech have merged J-Tag, Motorola BDM/Nexus and Bootloader Mitsubishi/Infineon Tricore/ST communication lines into a single product.
K-TAG works in perfect harmony. Learn how to use K-TAG takes almost no time, because all the communication protocols operate along similar principles. Once you have learned to use a protocol, you will naturally use all the others. Alientech knows what it means to work in motion. For this reason the research methods of the protocols and choice of vehicles are detailed and ordered.
Unlike many ECU programming tools, with K-TAG you have at your disposal only the applications you really need. Once you have the hardware, you can choose which group of protocols to enable and then start working. In this page you can find a complete list of the ECU currently supported by K-TAG.
Cables From Left to Right:
[img]http://www.chinasinoy.com/upload/temp/images/ktag-cables.jpg[/img]via: [b][url=http://www.chinasinoy.com/service/ktag-k-tag-ecu-programming-tool-vedio-262.html]http://www.chinasinoy.com/service/ktag-k-tag-ecu-programming-tool-vedio-262.html[/url][/b]
