Labor hours??
Home / Forums / Shop Operations / Labor hours??
- This topic has 3 replies, 2 voices, and was last updated 16 years, 3 months ago by Ben Hart.
- June 22, 2010 at 5:15 am #22020
I need the amount of hrs it calls for in the books to remove and install a Fox Body Mustang roof?? Its on an 83.. All the glass is outta the car, so that would also lower the amount of hrs and reduce cost..
Any help from you shop owners will be greatly appreciated 😉
[b]BondoKing wrote:[/b]
[quote]I need the amount of hrs it calls for in the books to remove and install a Fox Body Mustang roof?? Its on an 83.. All the glass is outta the car, so that would also lower the amount of hrs and reduce cost..Any help from you shop owners will be greatly appreciated ;)[/quote]
The furthest back I can go is 87 (which is basically the same). I’ve added the glass times so you can deduct them. All times are from a 1999 edition Mitchell manual.
Roof Replacement: 19.0 (Sedan)
20.5 (Hatchback w/sunroof)
18.0 (Hatch w/o Sunrtoof)
R&I Drip Rail Mouldings 0.2 (each)
R&I Back Glass (Sedan) 1.8
R&I 1/4 Glass (Sedan) 1.3 (each)
R&I 1/4 Glass (Hatchback)1.1 (each)
R&I Windshield 1.9 (R&R is 1.5)
Refinish Roof 2.8 (plus clear time if necessary) - AuthorPosts
