Machine prep clear
Home / Forums / Main Forum / Paint and Refinish / Machine prep clear
- This topic has 6 replies, 4 voices, and was last updated 13 years, 9 months ago by Dan Lewis.
- May 30, 2012 at 6:48 am #37064
I pretty much use a da with interface pad to prep all my panels that dont need blocking,then I still cheat and use a skuff pad around the edges and close to bodylines. I dont block and wetsand unless its something that I am doing for myself. Its hard enough to make any decent money with the insurance companies cutting your time and the cost of materials going through the roof. I dont consider it a bit lazy, what I concentrate on are processes that I can use that produce predictable, repeatable results.
May 31, 2012 at 8:26 am #37072[quote=”danthebumperman” post=26337]Good advice Chuck. I can’t find a 3″ interface pad, otherwise I’d use that to get a little closer to edges. You’re being smart, not lazy.[/quote]
Easy fix. Just cut a 6″ pad down to size if needed. I don’t bother though…I just hand finish the areas that my DA won’t reach (or sensitive areas such as panel edges etc).
I use a Rupes Scorpio 2.5mm random orbit palm sander with 500 grit to prep panels for paint (400 for DG).
