Masking wheel wells..
Home / Forums / Main Forum / Paint and Refinish / Masking wheel wells..
- This topic has 6 replies, 6 voices, and was last updated 13 years, 4 months ago by TLB.
- November 27, 2012 at 12:26 am #39417
Evening.
Just wondering how you all mask off wheel wells for painting?
I sometimes struggle and Ive noticed on here some people seem to be able to mask off the inner plastic liner and then mask off the wheel which looks like a real good way to do it, but how?
Most of the time I make the wheel well liner as clean as possible before prep and paint but even then the tape wont stick.
Lets hear your methods guys.
November 27, 2012 at 4:48 am #39423Here is an example…just back mask the wheel well with 1.5 inch then use 18inch paper around the wheel and well and tape it solid.Pretty simple and keeps dirt in.
[IMG]http://i580.photobucket.com/albums/ss241/jaysonm1969/015.jpg[/IMG]Same way I do it. When you bring the car in and pre wash it, make sure to hose out the wheel wells good (running your hand in there helps). Before masking I make sure it is dry (blow it well) and then wipe it with a rag (often using gun wash and/or water based cleaners depending on the contamination).
If I can back mask (like in Jaysons’s picture), that is my preference.Otherwise I will just tape up to the plastic liner making sure the tape extends around the lip of the liner so there is no paint edge.
Depending on the size of the openining and wheel you may need to get a little creative with the masking. On trucks, I may run some 36″ paper over the wheel first, then 18″ around the wheel opening on the fender. On some smaller vehicles a single piece of 36″ can work by masking around the lip and taping up the excess or trimming the paper to the opening…
November 27, 2012 at 11:27 am #39425Great advice guys. I usually do back mask around the edge then paper up to them. My trouble comes with modern cars as the flanges on wings/ fenders are rolled right round alot of the time. I have also used the duck tape method which works well although is expensive compared to masking tape.
