Mining Machinery Repair and Maintenance in Fote
Home / Forums / Main Forum / Auto Body Repair / Mining Machinery Repair and Maintenance in Fote
- This topic has 1 reply, 2 voices, and was last updated 11 years, 9 months ago by neemritkh.
- AnonymousJune 17, 2014 at 12:47 pm #46825
We must establish effective machinery management mechanisms, especially about the management of mechanical equipment maintenance. Generally speaking, there are several machinery management mechanisms:
1. Strengthen maintenance work to prevent maintaining wrongly or forgetfully. Because improper maintenance is one of the main causes of equipment failure, maintenance work must be executed forcibly. Maintenance manager must make effective maintenance program in accordance with instructions, and carry out spot check on its implementation. At the Fote time, we should establish incentive mechanisms, reward the good and punish the bad in order to strengthen the sense of responsibility, arouse their enthusiasm and motivation, and improve maintenance work effectively to ensure the normal operation of machinery equipment. Therefore, maintenance work should be implemented from the roots and prevent using repair replace maintenance.
2. Strengthen daily inspection. The inspection results should be recorded. The record should not only include previous maintenance records, but also include daily usage and workload records in order to analyze, judge mechanical failure, and eliminate hidden faults timely and accurately.
3. The maintenance managers should realize and command the situation, make a reasonable, detailed mechanical maintenance plan, and give instructions and supervision to maintenance work in order to avoid unnecessary waste of repair and maintenance.
4. Strengthen maintenance management, establish regulations of mechanical repair, and maintenance, emphasize the role of maintenance management; improve statistics system and record every fault; strengthen management of purchase, processing, accessories, etc. to ensure the quality and quantity of machinery parts.
As a result, we can see the influence of repair and maintenance on machinery performance. To say the least, wrong maintenance will reduce production efficiency and cause quality problems. Seriously, it will cause the device stop functioning, affect the operation of production line and cause significant losses. Thus, we can see that enhancing mechanical equipment maintenance and repair is an important way to improve machinery performance.
Fote Brand is the China Famous Brand, and Fote believes that reliable and stable quality is the key to success. Our products like [url=http://www.chinafote.com/pro/p10.html]vibrating screens[/url], [url=http://www.fote-machine.com/product/flotation-machine.html]flotation separator[/url] are well known at home and abroad. Welcome to visit for cooperation, thank you!
active lime plant: http://www.ft-dryer.com/products/Active-lime-production-line.htmlAwww.. My friends are saying this movie is not up to the mark!!
https://www.facebook.com/22jumpstreetinfoonlineget%5D5-the-marked-ones-online/
both their friendship and the case placed in jeopardy.Like the “Scream” franchise, “22 Jump Street” goes to great lengths to single out the inherent flaws and routine difficulties with a specific genre – here, sequels in general (though the action comedy genre is also a target). While budgets increase exponentially, stunts, props, scripts, actors, and, most importantly, laughs are commonly less rewarding. Although the first few
