Operation and Reform of Ball Mill Is Designed to R
Home / Forums / Main Forum / Auto Body Repair / Operation and Reform of Ball Mill Is Designed to R
- This topic has 0 replies, 1 voice, and was last updated 11 years, 9 months ago by dream.
Ball mill equipment and the development of technology, with emphasis on the energy consumption ofgrinding mills and steel consumption.We have developed a new type of high efficiency and low energy consumption ball mills equipment,We improved the structure of ball mill cylinder liner material and shape;We improved the shape and material of ball mills medium ,We improve the ball mills transmission way andball mills set automatic control,etc.Hongxing mining machinery to guarantee under the premise of ball mill product fineness ,To further improve the efficiency of ball millsyield ratio and the grinding mills, reduce energy consumption of ball mills,steel consumption and yield criterion.Maintenance times and time can according to each of the manipulation of wetgrinding mills,At the same time , it also depends on the most vulnerable parts or the easiest grind, liner wear degree.Ball mill maintenance in addition to routine maintenance inspection,according to the length of time for minor repairs, repair and overhaul of three is also very necessary.
The development of ball mills equipment:
(1)overhaul.In generally,The Overhaul cycle is in five years.Its inspection items includes all repair project, and change the main bearing and big gear.Hongxing mining machinery inspection, repair or replacement cylinder and end cover.Then we carried out on the basis of repair, alignment, or secondary grouting.
(2)to repair.In generally ,it is 6 ~ 12 months at a time.Our inspection items in addition to including all minor repair project, we still need to make larger equipment parts cleaning and adjustment.The big driving gears such as repair, etc., at the same time to replace a lot of easy wear parts.
(3) minor repairs.In generally,We have a small maintenance 1 ~ 3 months.Ourinspection items are mainly inspect, repair or replacement has been worn parts.Such as wet grinding mills liner, feeder spoon head, small gear, shaft coupling and rubber gasket, feeding tube, discharge tube, electric thoughts bearing, etc.We need to check all fasteners oil pump and lubrication system for inspection, cleaning and oil changes.If there is a temporary accident, timely repair and the wear of the minor, bare.
For each planned downtime of the inspection can work smoothly, we should do well in maintenance on-site, at ordinary times, recorded in detail each equipment control conditions and the effect after repair.We should be prepared for maintenance on-site, at ordinary times, recorded in detail each equipment control conditions and the effect after repair.
pin crusher: http://www.sell-crusher.com/pro/p17.html
