Pad removal for the Hutchins 4500
Home / Forums / Product Reviews / Equiptment / Tools / Pad removal for the Hutchins 4500
- This topic has 3 replies, 2 voices, and was last updated 13 years, 6 months ago by Joe t.
- September 23, 2012 at 5:14 am #38356
If you lookon the side of the da you will see a small tube coming off it, you can take a small screwdriver and stick that in their and then turn the pad until it locks. Their is little grooves that it will lock into, then just spin the pad off. Great da by the way, will last forever if you keep a little oil in it, I have one that is well over 15 years old.
Thanks a ton man, I was hooked on the quick release thing lol and when I tried to take it off without going through that whole it kept slipping off. So what is the actual use of that hole I always thought it might be for the hose to use as a watersander but wasn’t sure. As old as these sanders are you would figure the internet would be littered with breakdowns and rebuilds on them.
