Painting a Plastic Gun
Home / Forums / Main Forum / Paint and Refinish / Painting a Plastic Gun
- This topic has 2 replies, 3 voices, and was last updated 13 years, 7 months ago by Nelson Hays.
- AnonymousJuly 20, 2012 at 5:27 am #37662
I’m trying to identify this plastic off a 22, its for my cousin wants its sprayed flat black. Any idea what this thing would be made of? Thinking I should just go plastic cleaner, scuff, adhesion promote..any input?
Attachments:The type of plastic really doesn’t matter, just weather or not you need adhesion promoter. Take a razor blade to a hidden edge and scrape off a very tiny sliver of plastic and put it in water. If it floats, use adhesion promoter, if it sinks, you won’t need the promoter.
Prep and paint as usual…
July 20, 2012 at 10:45 am #37666[quote=”Ben” post=26871]The type of plastic really doesn’t matter, just weather or not you need adhesion promoter. Take a razor blade to a hidden edge and scrape off a very tiny sliver of plastic and put it in water. If it floats, use adhesion promoter, if it sinks, you won’t need the promoter.
Prep and paint as usual…[/quote]
that is a very cool trick!
I generally use AP regardless, when it’s an unknown plastic. I work with ABS, PVC, Acrylic, and UMWH on a regular basis, and occasionally bond to PP and PO in factory interior panels – the stupid factory plastics require AP about 99% of the time….. It took me about a year of little projects before I really got comfortable bonding and spraying all the really gay ones.
