painting interior vinyl ie dash and door panels
Home / Forums / Main Forum / Paint and Refinish / painting interior vinyl ie dash and door panels
- This topic has 3 replies, 4 voices, and was last updated 13 years, 6 months ago by Thomas Robertson.
- December 26, 2012 at 12:04 am #40066
Im looking for an easy diy method of painting soft vinyl . Im not looking to use any special vinyl painting product cuz they seem to suck . I need a sure fire way to spray base coat clear or some single stage. issues I see are soft vinyl areas such as door panels and parts of the dash and last issue the textured surface …..should this be sanded and smoothed out? should I use obviously adhesion promoter but should I use a sealer or can I get away with using a 2K sufacer/ sealer on this surface? sholud I bondo or polyester putty the soft vinyl areas to create a smoother and more rigid suface? any tips even if it may seem like hackery would be greatly appreciated
Some paint systems have a vinyl resin that can be mixed with the base toners. Chroma base had this as does PPG. I believe in both they have you clean and lightly abbrade the surface, apply adhesion promoter then the mixed vinyl paint. As far as I recall no primer or sealer is needed. I have used it in DuPont and it seemed durable after drying
[quote=”exodus” post=29055]Im looking for an easy diy method of painting soft vinyl . Im not looking to use any special vinyl painting product cuz they seem to suck . I need a sure fire way to spray base coat clear or some single stage. issues I see are soft vinyl areas such as door panels and parts of the dash and last issue the textured surface …..should this be sanded and smoothed out? should I use obviously adhesion promoter but should I use a sealer or can I get away with using a 2K sufacer/ sealer on this surface? sholud I bondo or polyester putty the soft vinyl areas to create a smoother and more rigid suface? any tips even if it may seem like hackery would be greatly appreciated[/quote]
Sounds like you want a glossy finish like the exterior of the vehicle? If so there are a few ways. Either you can fiberglass over the soft parts with 3 or 4 layers of matt, smooth out, prime, paint. Or you can do like this: http://www.refinishnetwork.com/component/kunena/8-auto-body-repair/26742-custom-dashboard#26946 As for the hard plastic I usually sand a bit of the texture out, clean with a plastic cleaner, adhesion promoter, high build 2k primer, block it out, prime again, sand and then paint.
March 5, 2013 at 3:04 am #41805Some may disagree with me but this works for me. Instead of vinyl dye (expensive and not all that good) I usually spay a urethane base with a little urethane hardner added to the base. It dries well and seems to last as long as the dye. A little adhesion promoter never hurts.
