Qualities of Square-Cone Mixer, working principle,
Home / Forums / Main Forum / Auto Body Repair / Qualities of Square-Cone Mixer, working principle,
- This topic has 0 replies, 1 voice, and was last updated 11 years, 8 months ago by fdbfdb.
Product overview the material into a square cone airtight mixing barrel, hopper symmetry axis and also the rotation axis at an angle towards the different component components, 3D motion in the discharging door closed, create robust turnover and diffusion impact, attain the best mixing results. The novel style, compact structure, stunning appearance, the mixing uniformity of 99%, volume filling coefficient 0.8. Rotary low height, steady operation, trustworthy efficiency, practical operation; cone to skip form, can recognize the material [url=http://www.yibu-dryer.com/air-stream-spray-dryer-62.html]Air Stream Spray Dryer[/url] transporting, prevent the pollution, conforming to GMP specifications; internal and external wall of the barrel body by polishing the surface, no dead angle, easy to discharge, simple to clean.
Square cone mixer with novel style, compact structure, stunning look, superior effect. For most applications, a few of the pharmaceutical sector, the mixing uniformity of 99%, the maximum load element reached 70%, is a classic solutions in Square-Cone Mixer.
Just after the big vertical lathe processing just after the inner wall on the barrel physique and finely polished, let you no dead angle, no pollution in mixing, discharging the material inside the weight under the smooth discharge, leaving no residual material, make you much more stable when mixed.
Material is mixed inside a closed state, has no pollution for the operating [url=http://www.yibu-dryer.com/inner-heating-fluid-bed-dryer-57.html]Inner Heating Fluid Bed Dryer[/url] atmosphere. Charging low height, handy operation.
The outer surface and also the components contact with material are produced of Hopper Mixing Machine, the production of sophisticated, meets GMP specifications
Functioning principle.
The material into a square cone airtight mixing barrel, mixing barrel symmetry axis along with the axis of rotation into an included angle, diverse material in 3D space motion inside the mixing barrel closed, produce strong turnover and diffusion contraction, attain the [url=http://www.yibu-dryer.com/conical-vacuum-drying-equipment-1764.html]Conical Vacuum Drying Equipment[/url] ideal mixing results.
