Removal of Dent from Frame. NEED HELP!!!
Home / Forums / Main Forum / Auto Body Repair / Removal of Dent from Frame. NEED HELP!!!
- This topic has 1 reply, 2 voices, and was last updated 15 years ago by Don Wedor.
So, first question is 1) How do I put a new window in the far back passenger side and 2) Is there anyway possible that I can pull that dent out my frame, anyway possible would be greatly appreciated I know i can rent a Slide Hammer dent puller but i was wondering if there was any other way using common garage itmes. I would greatly appreciate your help,
Thank-You,
Tyleri would recommend and auto glass place install the new window and as for the dent in the frame well umm ya i would take it and check the alignment to see what all else happned you might need to put it on a frame rack at a bodyshop to have it fixed
most good shops can atleast take a look at it for you to tell you what else is wrong with it.- AuthorPosts
