Repairing Gel coat peeling off Vette
- This topic has 1 reply, 2 voices, and was last updated 15 years, 10 months ago by .
Home / Forums / Main Forum / Auto Body Repair / Repairing Gel coat peeling off Vette
I am attempting to repair several places on an 80 Vette where the Gel coat is separating from the fiberglass. What can I repair the holes with or what technique should I use to prevent any problems with the repair material lifting from the fiberglass in the future. I recently repaired some damaged fiberglass with bondo and polyester filler and two weeks later it began to blister and lift off the repaired areas. What is the correct repair procedure and materials.
I’ve had pretty good luck with fiber tech on vettes.
http://evercoat.com/imgs/salesflyers/FiberTechFlyer.pdf
