sata 3000
Home / Forums / Shop Operations / sata 3000
- This topic has 19 replies, 10 voices, and was last updated 13 years, 7 months ago by Jayson Munro.
- November 27, 2012 at 4:09 am #39421
No, the air passages internally are different. It would be nice wouldn’t it!
November 27, 2012 at 4:10 am #39422no, done it, takes the gun out specs. i did it, didn’t work to good. you’ll end up spraying at an higher psi. plus it’s like 300 bucks for a new needle, nozle, and cap, a few more and you have a whole new gun.
November 30, 2012 at 8:06 am #39480Jayson has the experience with the new rp, he says its far better then the 3000, i have used the the hvlp, & liked far better then the 3000.
I did end up spending the coin for a new 1.4 tip kit for the rp, & been much more happier clearing with it then i was with the 1.3.
November 30, 2012 at 8:32 am #39482[quote=”lild” post=28524]Jayson has the experience with the new rp, he says its far better then the 3000, i have used the the hvlp, & liked far better then the 3000.
I did end up spending the coin for a new 1.4 tip kit for the rp, & been much more happier clearing with it then i was with the 1.3.[/quote]
At first I really liked it,and it does lay down a nice smooth coat of clear.I do find it a little on the slow side even with a 1.4,but still use it.My gun of choice is still the first gen RP with a 1.4,the 3000 is a nice gun too,just not my fav 😛
December 3, 2012 at 2:54 am #39618[quote=”protek9543″ post=28638]With the EPA’s 6H rule all spray guns are more likely to spray like HVLP guns. They will slow you down.[/quote]
Sata RP’s do not spray like HVLP,not even close,they spray just as fast as my sata jet 90 😛
[quote=”Jayson M” post=28643][quote=”protek9543″ post=28638]With the EPA’s 6H rule all spray guns are more likely to spray like HVLP guns. They will slow you down.[/quote]
Sata RP’s do not spray like HVLP,not even close,they spray just as fast as my sata jet 90 :P[/quote]
The Sata RP3000 does not spray like the Jet90. My post was the effeciency of spray guns has changed. The Jet90 is not an RP (reduced pressure).
December 3, 2012 at 3:45 am #39623IMO it does in regards to speed and how much material it puts out, you just have to be closer with the 3000.I sprayed with a jet90 for ten years( it was satas first gun to deliver 65% transfer efficency at 50psi) and have owned and used all the rp’s…
December 3, 2012 at 7:10 am #39627Sprayed dc5335 with a rp3000 and a 1.2 little slow. the 1.3 will be fine
