Sealer over aftermarket flat paint?
Home / Forums / Main Forum / Paint and Refinish / Sealer over aftermarket flat paint?
- This topic has 6 replies, 5 voices, and was last updated 16 years, 1 month ago by james caruso.
Hey guys, I am in the process of repainting my car for the second time. I have begun to sand the existing single stage flat red with 400, and have sanded through to my original clear. My car was originally red before the respray, so it is just a few shades lighter where it was sanded through. My question is, do you suggest I spray a sealer down before spraying my new basecoat? The new paint is a dark metallic brown.
I’m thinking I wont have any adhesion issues with the basecoat and single stage flat red, because they are made by the same company (TCP Global.)
Thank you for your help.
P.S. The car in question:
[IMG]http://img.photobucket.com/albums/v209/darrentiffany/LH1.jpg[/IMG]
January 14, 2010 at 10:27 pm #18635myself i would just seal it cant hurt an it will do nothing but help 😉
AnonymousJanuary 15, 2010 at 12:09 am #18641You could also just apply the sealer over your breakthoughs, the only concern I’d have otherwise would be lifting if you apply the base coat over those area’s. Sealing the whole job won’t hurt but if you’ve already painted the car once your getting your mil thickness up and your paint durability can decrease, may want to consider skipping the sealer for that reason. I don’t think it will make a huge difference either way but something to consider.
January 15, 2010 at 3:13 am #18647if it were me i would seal it just to help eliminate wrinkling or edge mapping of all the burnthrough spots, especially if its a metallic. spi sealer locks up nice and quick to help with this. 400 hand sanding is a bit too coarse but 400 with a softpad on a da will be finer and ok otherwise 600 if no sealer or hand handing.
