Spraying a factory Panel
Home / Forums / Main Forum / Paint and Refinish / Spraying a factory Panel
- This topic has 10 replies, 4 voices, and was last updated 15 years, 8 months ago by jackcarlson.
Hello all,
My daughter hit a pole ( she is ok) but took out the right side of the truck. My question is I have a factory replacment panel, would you recommand priming it, or scuff it with 400 and shoot the base coat? BTW I will also repaint the bumper skin which I picked up.
Thanks for the help.
John [img]http://www.refinishnetwork.com/media/kunena/attachments/legacy/images/DSC_0475.JPG[/img] [img]http://www.refinishnetwork.com/media/kunena/attachments/legacy/images/Photo0255.jpg[/img]
Attachments:June 9, 2010 at 1:28 am #21815you want to shoot a sealer over it before you put any base on it otherwise it wont last
June 9, 2010 at 3:18 am #21820if the cover comes pre primed dont use adhesion promoter on it an ya should seal both parts the fender an the cover b4 ya base ta check the cover to see if its preprimed scuff it in a spot with some 600 an see if ya get blk color on the paper if not then ya will need an raw plastic adhesion promoter b4 ya seal 😉
