Structural attributes, Micro-Particle Grinder oper
Home / Forums / Main Forum / Restoration / Structural attributes, Micro-Particle Grinder oper
- This topic has 0 replies, 1 voice, and was last updated 11 years, 8 months ago by fdbfdb.
Operating principle.
In the upstream approach of hot molten state of supplies by way of the cloth granulating machine (appropriate) are uniformly distributed on the strip beneath the moving on, with continuous spray, cooling device is arranged beneath the steel strip, forcing the above material to rapid cooling, curing in the moving approach, so as to attain the purpose of granulation molding. According to the properties and use, the distributor can choose the intermittent drips, continuous brace and full width overflow and also other forms, inside the production of [url=http://www.yibu-dryer.com/air-stream-spray-dryer-62.html]Air Stream Spray Dryer[/url] hemispherical, strip and sheet items. The granulation procedure, can choose external rotation kind, rotary, reciprocating, vibration kind cloth to type; condensed sheet breakup process, can pick the gate form, tube form, multi roller rolling cloth type; for the cooling method of solid powder, also could be employed for vibration cloth cloth type.
According to the want of material, process and layout, the condensation curing sheeting crushing method or the cake shape material cooling process, but in addition can double or chemical granulator Higher Effect Grinding Machine(set), to be able to lessen the occupied location from the gear and additional strengthen the cooling efficiency of heat exchange.
[img]http://www.yibu-dryer.com/datacache/pic/320_244_1013ca0d0440f5aff7bd09471f522b98.jpg[/img]
Scope of application:This type of device is appropriate for the melting point (softening) cutting or cooling of sheet forming all kinds of material crushing at 250 ?? for condensing pelletizing, brace, typical application materials: sulfur, paraffin wax, resin, asphalt, maleic anhydride, trimellitic anhydride, stearic acid solutions, hot sol, organic intermediate, compound fertilizer, rubber and plastics as well as other aspects from the auxiliary solutions and so on..
Fast cooling method of this kind of device could be widely applied in powder material and cake sticky material, like emulsion explosive matrix, crystal stone matrix, sodium fluosilicate etc..
The primary benefit:
Strip and distributing device adopts frequency conversion speed regulating, based on production capacity, environmental circumstances and physical properties of convenient adjustment and handle.
Use, repair:
The machine just before use, should really verify the screw steering, is reversed, [url=http://www.yibu-dryer.com/conical-vacuum-drying-equipment-1764.html]Conical Vacuum Drying Equipment[/url] otherwise it can harm the components.
The machine prior to use, must verify the screw steering, is reversed, otherwise it’s going to harm the components.
The machine ahead of the start out, start off the electromagnetic adjustable speed motor, soon after the commence of geomagnetic table speed (slow), screw to a certain speed range after feeding production.
Just about every six months verify, replace the speed reducer, gear box lubrication oil amount, the usage of 40# oil.
Each and every six months check, replace the speed reducer, gear box lubrication oil quantity, the use of 40# oil.
Join host the Micro-Particle Grinder, is refers towards the dispersion and mixing of moisture moisture content, kneading degree.
Granulation components essential for some state is strong dispersion has plasticity, particular stereotypical efficiency, namely the hand produced a ball shape, loose basically unchanged following an apparent phenomenon. Granulation supplies needed for some state is solid dispersion has plasticity, specific stereotypical efficiency, namely the hand made a ball shape, loose generally unchanged immediately after an [url=http://www.yibu-dryer.com/inner-heating-fluid-bed-dryer-57.html]Inner Heating Fluid Bed Dryer[/url] apparent phenomenon. Particle size can be changed in line with want hole extrusion template to regulate, manage.
