The Notes deserve special attention for Cone Crush
Home / Forums / Main Forum / Introductions / The Notes deserve special attention for Cone Crush
- This topic has 0 replies, 1 voice, and was last updated 11 years, 9 months ago by dream.
The working environment of mineral crushing equipment is bad in general for it has to bear the sun, the wind and the rain. And the stone powder produced in crushing process will influence the operation of the equipment. Some investors, after buying cone crusher, don’t maintain and repair the equipment very well so that there are some faults in the operation process.Therefore, if you want to ensure the normal operation of rock cone crusher, the normal work must be done. Attention should be paid to the following pA cone crusher is generally used as a secondary crusher in a crushing circuit. Cone crushers are designated in size either by the gape and mantle diameter or by the size of the receiving opening. Cone crushers can be used for primary or secondary crushing. Cone crushers are used extensively throughout the aggregate and mineral processing industryroblems in the operation. Only in this way can we guarantee the normal work of the equipment.
The equipment is easy to have some failures for two factors: firstly, it is because the working environment of china cone crusher is poor. Secondly, it is inevitable to crush the hard rock and wear the equipment. We should check and maintain the equipment properly after the equipment is used for a certain period of time.
The installation of deiron equipment for cone crusher is necessary. Frequently rubbing the iron will rupture the axis, so the large-scale cone crusher manufacturer will equip their equipment with iron removal device before selling. In the feed equipment, we must ensure even feeding, otherwise, it will lower production capacity of the equipment. The size of the product into the equipment must be controlled well and avoid the big size, otherwise, it will cause spring move frequently, bring too much pressure to the bearing, improve the power consumption. The oil temperature on the equipment also must be controlled well, and the temperature cannot be too high or too low.
cone crusher: http://www.made-crusher.com/productslist/70.html
