What Is Your Impression of a Ball Grinding Mill ?
Home / Forums / Main Forum / Introductions / What Is Your Impression of a Ball Grinding Mill ?
- This topic has 0 replies, 1 voice, and was last updated 11 years, 10 months ago by dream.
In people’s impression, the application of sand making machine equipment environment tend to be high, dust billowing.In recent years, the mining machinery equipment companies in terms of production technology of a wide range of the update.New environmental protection and energy saving equipment costs are rapidly reduce as the industry scale and technology progress.The Ball Mill is used to grind many kinds of mine and other materials, or to select the mine. It is widely used in building material, chemical industry, etc. There are two ways of grinding: the dry way and the wet way. It can be divided into tabular type and flowing type according to different expelling mine.
Features:
1. It is an efficient tool for grinding many materials into fine powder.
2. The ball mill is used to grind many kinds of mine and other materials, or to select the mine.
3. Ball mill is widely used in building material, and chemical industry.
4. There are two ways of grinding: the dry way and the wet way.
5. Ball mill can be divided into tabular type and flowing type according to differentexpelling mine.
6. To use the ball mill, the material to be ground is loaded into the neoprene barrel that contains grinding media.
7. As the barrel rotates, the material is crushed between the individual pieces of grinding media that mix and crush the product into fine powder over a period of several hours.
8. The longer the ball mill runs.
Application:
Working Principle:
Materials enter into the first grinding chamber through hollow shaft. There are liner of ladder type or curve type, and steel balls of different specifications in the first grinding chamber. The centrifugal force caused by turning of he barrel take balls into a certain height inside the chamber, and then balls fall down, have striking and grinding effect on materials. Materials after primary grinding in the first grinding chamber is fed into eh second grinding chamber through single layer chamber dividing plate. There are flat liners and steel balls in the second grinding chamber. The balls make further grinding effect on materials. Finished powder which meet requirement is discharged through discharge grade plate and the grinding work is finished.
ball grinder:http://www.sell-crusher.com/pro/p15.html
