clear coat problem – newbie
Home / Forums / Main Forum / Paint and Refinish / clear coat problem – newbie
- This topic has 3 replies, 3 voices, and was last updated 16 years, 5 months ago by brandon dingwell.
Its my first post here so i want to say Hi all ! 🙂
I was repairing some rust points on my 94 Isuzu Trooper. Everything was fine until i sprayed clear coat ( BASF Salcomix Ergoclear 2K) on base coat ( BASF BC Diamont). It was my first time doing some car painting before that i was only painting model kits with airbrush – so i don’t have a big experience. Colour is exactly this same as original but its mat :unsure:. Between base and clear there was about 15 minutes. There are 3 layers of clear coat. I was using airbrush with 0,2 mm nozzle. I dont know where i made a mistake ? Why its mat and how can i fix it !? Here you can see photos :
[img]http://lh6.ggpht.com/_CItfJBI02Vs/S9XSHCWQHBI/AAAAAAAAAxA/_yAEIUOz2Wk/s640/PICT0249.JPG[/img]
[img]http://lh5.ggpht.com/_CItfJBI02Vs/S9XSCUB6Q5I/AAAAAAAAAw0/yuJ5Sucibi4/s640/PICT0248.JPG[/img]
[img]http://lh3.ggpht.com/_CItfJBI02Vs/S9XSJO0RXEI/AAAAAAAAAxs/gVRpeG9Msyc/s640/PICT0250.JPG[/img]
Thank You ! :cheer:
April 27, 2010 at 12:24 am #20903An airbrush will be too small for what your spraying. Look into a touch up gun or a full sized gun.
April 27, 2010 at 2:13 am #20906normally you might be able to buff but I doubt there is enough material on there to do so. you will be lucky if those 3 coats with the airbrush equal what 1 coat would be with a normal gun
