Color code 1F2
Home / Forums / Main Forum / Paint and Refinish / Color code 1F2
- This topic has 2 replies, 3 voices, and was last updated 12 years, 11 months ago by Ben Hart.
- AnonymousOctober 29, 2013 at 11:04 pm #45154
I have a big problem. I can’t seem to get code 1F2 to blend. Im using Sherwin Williams AWX waterborne base. While Im laying the base down everything looks fine, but when I clear it all shows up. The blend looks blotchy. I’ve shot this color 3 times now with the same result. I dont think its me. I think it has something to do with the metallics in it. It has a very fine metallic and a medium size with a good sparkle. Any ideas? Thoughts? Im tired of going down the whole side of a vehicle. Thanks
October 30, 2013 at 2:53 am #45155if you get your flop or sidetone ta match it will blend 😉 thats whats kickin ya in the nards its either going ta be 2 dark or light or check your alts ta see what they have …..hope this helps i checked my computer an it looks like alt A may be the one ur looking for
I spray AWX as well. Bondo is right, you need the variant with the best side tone (flop). The face is less important. Try using the slow (030) basecoat reducer as well. Are you using the 0500 blender/wet bed at all? What gun/setup are you using and how are you spraying your orientation coat?
The metallics (especially the medium and finer ones, 411,412, 413, 414) usually spray easily and blend very well.
