COMPACT PAINT SYSTEM…….
Home / Forums / Main Forum / Paint and Refinish / COMPACT PAINT SYSTEM…….
- This topic has 1 reply, 2 voices, and was last updated 11 years, 11 months ago by Anonymous.
I have a bulldozer that I am restoring. I understand there is a paint system that will allow you to spray the primer then spray the color right away… kinda like wet on wet. I am sandblasting all the parts and would like to shoot everything without having to sand the primer. I’m not sure if all the manufacture’s make such a system but I know somebody has to….. can anybody point me in the correct direction? just looking for a single stage system… thanks
AnonymousApril 27, 2014 at 1:07 am #46478After you finish sandblasting, the metal will be a bit to rough to go wet on wet but I guess it all depends on what you want the end result to look like. You can lay down an epoxy wet-on-wet sealer, then any urethane singlestage, For me in BASF I would use EP369 epoxy and UNO singlestage. Every paint line will have similar products available.
