Paint blistering over fiberglass repair
Home / Forums / Main Forum / Auto Body Repair / Paint blistering over fiberglass repair
- This topic has 6 replies, 4 voices, and was last updated 15 years, 9 months ago by jackcarlson.
- May 19, 2010 at 4:54 pm #21354
Recently I attempted to repair fiberglass panels on a stepside Chevy truck where someone had removed the body side moldings. I filled in the damaged fiberglass with polyester putty, primed with 2k and painted. About 2 months later the paint has began to blister over the repaired areas. What did I do wrong and what can I do to repair and prevent this from happening again
May 19, 2010 at 8:34 pm #21356I have already removed the blistered paint. The blistering was in the paint and primer only. None of the filler was affected.
May 19, 2010 at 9:51 pm #21359The blisters were about the size of your thumb. I have sanded the area and reprimed with several coats of 2k. I am gonna let it dry troughly then block reprime, seal and repaint. Does this sound like the way to go?
May 20, 2010 at 12:07 am #21361so your telling me ya didnt reglass the damage right ””well what happend is the water got in the backside of the repairs an came out thru the top of the poly putty grind it all out an reglass it witch is water proof an then finish it with ur poly an ya wont have a problem ya could even just duraglass it then do ur fill hope this makes sense an helps 😉
