SIA ‘Carat’ Velvet 7240 3000 Grit
Home / Forums / Product Reviews / SIA ‘Carat’ Velvet 7240 3000 Grit
- This topic has 3 replies, 2 voices, and was last updated 12 years, 8 months ago by Charles Smith.
- June 19, 2013 at 5:41 am #43417
Where did you find these and whats the price compared to the Mirka? I have been using the Mirka 3000 for awhile now, I stopped using the 2000 due to the pigtail issues that you described earlier.
[quote=”Idunnit” post=32184]Where did you find these and whats the price compared to the Mirka? I have been using the Mirka 3000 for awhile now, I stopped using the 2000 due to the pigtail issues that you described earlier.
Chuck[/quote]
It was a sample from the SIA rep at my jobbers open house, he did say it was pricey $25 per, not sure if that was a box of 2 or just a single. However, if it does last 40 times longer than ‘conventional’ abrasives, it might be worth it. When I mentioned the pigtails I was getting, he said it was from the minute balls of glue in the Mirka discs…maybe.
June 19, 2013 at 6:44 am #43420I found that if I soak my mirka in a mixing cup with a few drops of soap between uses it cuts down on the pigtails. Just rinse it out before use.
