what size sould i use
Home / Forums / Main Forum / Paint and Refinish / what size sould i use
- This topic has 8 replies, 6 voices, and was last updated 14 years, 4 months ago by Hernandez.
- October 5, 2011 at 12:40 pm #33374
Hi all i am buying a devilbis GTI w what size nosel etc should i get one for clear and one for basecoat. I have been told a 1.3 for base and a larger one for clear, can you help please thanks richard
October 5, 2011 at 3:13 pm #33375There s no good answer to that question. It is really based upon what specific basecoat and clearcoat your using. A 1.3 and a 1.4 are pretty universal but there are exceptions.
One word of caution on the GTI, they are air hogs and require around 15cfm. Make sure you have a sufficient air supply and the proper piping, hose size and length, and high flow couplers or the GTI will not perform well.
are you buying a gti or a gti pro
You could probably get away with 1.3 for base and clear and maybe have different air caps for each
This link will tell you what setup is best for each paint type
http://www.devilbisseu.com/en-gb/downloads/paint-and-gun-match
If for example you were using Lesonal Wb you would use a 1.3 setup for both and H1 cap for base, and a T1 cap for clear
October 7, 2011 at 4:31 am #33408Why don’t you convert those guns to a plus compliant(like an rp) gun.The GTI is slow,an air hog and not that great of a clear gun,tossed mine 12 years ago,would never use one again.The best gun going for devilbiss is a tekna.
[quote=”Jayson M” post=22867]Why don’t you convert those guns to a plus compliant(like an rp) gun.The GTI is slow,an air hog and not that great of a clear gun,tossed mine 12 years ago,would never use one again.The best gun going for devilbiss is a tekna.[/quote]
aaah! yeah been wanting to do this but keep forgetting… i would rather have a plus than a GTI though! my fault for getting the GTI’s… i believe they both the same price too! or maybe 10$ more or so.
